Having no luck at the minute
We've had guests staying and I think someone has maybe flushed something they shouldn't have down the toilet. The shower, sink and toilet in the en suite share a main drainage pipe and it has been a bit... Sluggish since they have left along with other problems. When the shower is running, the toilet starts to gurgle and the water takes its time to drain from the shower (it is usually very fast). When the toilet is flushed, the shower drain hisses and gurgles and the trap moves up and down. When the tap is run the same thing happens. Whatever is causing the blockage, I don't think it is a *major* issue, so I was wondering if a bit of drain unblocker might work before I call out a plumber...
I also know that this could be caused by an issue with the vent. I'm not sure how to diagnose what the true culprit is so if anyone has any tips on doing that it would be very helpful.
