Hi everyone,
I'm in the process of purchasing a basement apartment in West-London at the moment as a first-time buyer.
As part of the full homebuyer's survey I did, the surveyor noted he could not comment on any of the plumbing/drainage within the flat. Given it's a building dating from the late 1800's, I would like to get this further checked out before executing the sale.
But I am a bit confused whether I would need a 'Drainage report', or a 'Plumber report'? Reading what they both do, it seems very similar to me..
What I want to get checked is whether all water taps (sinks, toilets, showers) etc are running fine, as well as if all the pipes inside/and serving the flat are in good conditions, free from any damages. And given the flat has some small visual damp issues, I would like to make sure this is not faulty drainage/pipes that cause this.
Do I need a Plumbers report or a Drainage report for this? Or are they the same? Reading online I suspect I definitely need some CCTV checking of the pipes/drainage.
Thank you so much for your help.
Cheers
T
Cheers
T
