Drainage
cja
31 May 2006
Hi, we have a drainage arrangement from two bathrooms and a kitchen that I would like to change around to use a different stack due to some other change I am making. I\\\'d like some advice as to whether my plans will work!
Current configuration:
Basement bathroom drains to stack #1
Basement kitchen and ground floor bathroom drains connect together and drain to stack #2
Desired configuration:
All drain to stack #1.
My challenge is that I have a 50mm vertical pipe from the ground floor bathroom, and then the basement kitchen is on a 40mm pipe and the basement bathroom on a 40mm pipe. Ideally, I\\\'d like to connect the ground floor bathroom (50mm) vertical pipe into the 40mm basement kitchen pipe, and then connect that 40mm pipe into the basement bathroom 40mm pipe.
Will this cause problems?
Thanks for any help,
charles.
