Hi All,
Yesterday I drained and refilled my (open-vented) central heating to add some cleanser. The system has inverted pipe loops and I drained from all 4 drain valves (though the water came out very slowly from one).
After refilling & bleeding, the heating didn't work at first, but turning the hot water and heating on and off a couple of times resulted in a lot of gurgling from around the 3-way valve (next to the hot water cylinder) and then everything started working fine. The heating also came on fine this morning.
But this evening:
- only one radiator is getting hot
- the return pipe to the boiler is cool
- the 3-way valve seems to be working OK
- I've bled all the radiators fine
- the pump seems to be working (though making a high-pitched noise which I don't think it used to)
I'd be really grateful for any help & advice!
Thanks,
Adam
But this evening:
Thanks,
Adam
