Ayup
We recently had a leak from one of the rad valves so I had to drain the system to replace this. Because of the location of the H+E tank it's nigh on impossible to prop the arm of the ballcock so I turned off the hot water valve and main water stop cock to bled the system.
I fitted the new valve, closed all the rad bleed valves and turned the mains back on to fill the system. All seemed fine but when turning the CH on I get a loud whooshing noise and banging from the pip between the boiler on the ground foolr and the pump above it on the first floor.
I blead all the rads and the pump and this has failed to resolve. Boiler works but heats for a couple of minutes then cuts out which isn't surprising as whilst all the pipes and rads are cold the pipe between the boiler and the pump is red hot.
read all the posts and tried everything except draining and refilling or backfilling from the drain point - HELP!
I have the floowing CH system;
Baxi Bermuda LFE 3 Super
Grundfos Pump
Open system
3 rads ground floor, 3 rads first floor, 1 rad dormer
H+E tank in dormer
Sorry for the long post but wanted to try and give all the info first time
Grundfos Pump
Open system
H+E tank in dormer
