Hi people.
Can you help? I need to drain my heating system to fit a vertical deaerator & dirt separator on my combi boiler as I keep having problems with the heat exchanger causing the hot water to run cold & hot. I was told to fit this as a cheaper option to having the system power flushed. Do I need to turn the gas off to drain and do I use an inhibitor, like Fernox ,on refill or not on a combi system. Cheers.
