DRAINING A WASHER ABOVE THE WASHER
21 Jun 2010
Michigan
Yesterday we purchased a new washer. Ive hooked it up, but the main drain line for the house is located about 6 feet directly above my washing machine.There is a U trap and a fitting coming off the end of the line that appears to be for the washer drain.
The set up requires me to drain the washer 5 feet above where the drain exits the washer.
I'm guessing when the drain cycle kicks off all the water in the house will drain back into the washing machine.
Should I install a check valve or one way valve right where it exits the washer?
run the washing machine waste into a sump pump :)
