I've decided to clean out my fresh water supply tank in my attic, after reading horror stories about bacteria and legionella etc.
Intend to drain it using a pump or syphon, then clean the inside with a sponge and brush etc, and continue with this until its spotless.
I'd like some advice on disinfection please. Any suggestions on best product?
Looks like chlorine is the main recommended way to go, which is the same as non-perfumed bleach, Its just weaker.
"The chemical in bleach is the same chemical found in liquid chlorine sold by you local pool store or hardware store. Bleach is just weaker by volume than liquid chlorine. Typically liquid chlorine is 10-12% Sodium Hypochlorite where bleach is about 5-6% Sodium Hypochlorite".
I also found this:
https://www.hunker.com/12002105/how-to-clean-a-water-storage-tank
http://www.cleanwaterstore.com/reso...rine-to-add-to-storage-tank-to-kill-bacteria/
Any views or advice? Thanks
I also found this:
