Having decided that Power Flushing my new system is going to be an expensive option I am going down the route of draining and cleaning the system myself.
I simply have a combi boiler and no tanks, to drain the system is it as easy as undoing the draining valve I have outside the house and letting gravity do it's job and the water flow out of the pipe, or do I need to do something with the boiler other than make sure it is turned off.
Once this is drained I then fill the system back up by closing the valve I opened to drain it and turn the tap on under the boiler which I use to top the system up after bleeding the rads??
When I have drained the system once I intend to then add chemicals to leave in there to try and cleanse the system can anyone recommend any?
When I finally fill the system I guess some sort of inhibitor would be good to add again any suggestions?
