- Joined
- 28 Dec 2016
- Messages
- 117
- Reaction score
- 4
- Country
Having decided to cut the grooves in my oak draining board I proceeded to get a secondhand mdf jig. As a one off so no need for expensive laminate one. Now jig os 17mm thick for starters. Measuring the slot at the oint where the groove will disappear it is 42mm from jig top to worksurface. Now my big problem is my 20mm round nosed bit will not reach the work surface at the end of the run. The instruction say the bit should just touch the worksurface at the end resulting in a groopve of 6mm at sink end. Problem is my bit is around 10mm short and unable to get good purchase in the router. TYHis is trying to use my 1/4 in Trend router. If I try to use my 1/2 in Makita I come across the problem that the fastening nut on the router will not pass through the 30mm guide bush. I have looked for cutter with longer shafts but having difficulty finding one. I have thought about modifying the jig not really sure whyit has such thick supports for starters.
Anyone any ideas.
Anyone any ideas.
