Hello, we have a combi boiler and a one pipe system.
I plan to drain the system inorder to remove all rads and pipes as all pipes are on the skirting right around the bungalow and replace with a 2 pipe system and new rads in new locations.
I wanted to see if I could save some money and do the first part (removal) myself as we are fine without heating.
I plan to turn off the water, drain the system from the drain valve I can see on the pipe, then chop the flow and return pipes in the loft (with a bucket under them) and fit an end cap on each pipe then remove everything?
Is this basically it?
Any advice/tips appreciated.
Many thanks
Many thanks
