I want to replace a two port motorised valve, Honeywell V4043, to the central heating circuit. The valve is on the top floor by the hot water cylinder. Do I need to drain the whole system or can I just drain the top floor? Must I latch the valves open during draining and refilling? Finally when the motorised body is removed is the valve left in open or closed position?
Mickma
Mickma
