- Joined
- 17 Mar 2011
- Messages
- 68
- Reaction score
- 1
- Country
Hi
I have an open-vented type heating system
with an oil boiler outside.
The small tank in the attic is disconnected and all the rads drained down but I need to drain the last drop out of the downstairs pipes so I can cut them flush and fit new laminate flooring.
The oil fired heating system is being removed as I don't use it anymore.There is no drain off lower than the pipework on the ground floor.Will I have to use a wet-vac or is there another method.
Thanks for any help
Thanks for any help
