My CH system appears to have a lot of black sludge in it and I want to flush it out.
I've found the two draining valves near a radiator by the front door - As far as I'm aware the next thing I should do is turn off the feed to the header tank and drain off from the draining valves via a hosepipe into a drain.
How do I proceed next ? Do I turn the flow to the header tank back on and bleed the radiators and then repeat the process again until the system is clean ?
Any advice would be great!
