Draining & Refilling a sealed system
17 Jul 2006
Leicester
Hi all, sorry if this has been answered before but I tried to look back but couldn't find any posts. Anyway
I am a competant DIY'r & can manage general plumbing jobs myself.
I have a sealed CH system - Worcester Highflow 400 RSF, Basically I need to change a radiator in the downstairs cloackroom but is a different size to existing one. So I need to drain the system to change the piping & valves.
Can I just turn off the CH flow & return valves, attach a hosepipe to the draincock at the lowest point and rain away?
Is it just as simple to refill once completed. Can I just open these 2 valves and then refill the pipes& radiators up again?
I know I will have to open the vent valves on the radiators when draining & refilling.
Any advice & tips would be greatly appreciated as I need to do this asap.
Many thanks, Jim
Hi
Hire a pipe freezer from local builder merchant.
No refilling and loss of inhibiter just a top up.
Hope this helps
Do what you said but turn your rad valves off to you may need to add more inhibitor too
Thanks, I intend to use
1. f****x central heating restorer
2. f****x superconcentrate central heating protector
(which I bought of fleabay for a tenner each) while I had the system drained, so wanted to drain it rather than freeze the pipes.
So what I said above should work then? Should I still keep the rad valves off on the other rads if I am going to use the above 2 items?
I intended to put the stuff into the new rad that I am going to install. Once the rad is all fixed up and I open the flow valves, I am just worried that I may damage the pump as there is bound to be some air in the system, from the pipes I have drained down. Would this be ok or should I be careful of something?
Thanks for the help & reassurance.
