Get a plumber in shouldn't cost that much £10.00 for valve and at the most 2 hours work max at £20.00p/h. Alternative, find the lowest point on the system to drain from, turn off boiler, open drain valve, after 5mins open bleed taps on radiators on top floor then 10mins later move down a floor, and so on, depending on how the system was piped the ground floor rads may or may not drain depending on whether the pipes come down from upstairs(drops) or up from the floor! Once drained change valve, then go round closing all bleed taps on radiators, and drain valve, then pressurise boiler to 1.5 bar and bleed ground floors rads till full then move up a floor, nipping back to boiler when the pressure has gone(cant hear the air hissing through the bleed valve) all radiator valves must be open before draining system! Turn Central heating on leave 30mins, re-check rads for air, re-check pressure top up to 1.5 bar no more!
