I want to drain my CH system down to see if it is clear, as I had trouble with a couple of rads not heating up during the winter.
The only drain point is on the hall radiator. If I drain from here the system will only be drained to the bottom of the down stair rads. If I then open the valve at the boiler to pressurise the system will that flush through all the pipework below the rads ?
Alternatively I could lift a floorboard and cut a pipe to allow it to drain into the space below. There's a good 18" below and it would only be the water from the low pipework.
Thirdly I could drill through the wall and fit a proper drain point off the low pipes but I don't want to involve myself in too much extra work unnecessarily.
Your advice will be appreciated.
