I'm replacing a Back-boiler system with a combi system. How do I drain the back boiler so I can remove the radiators and old pipes without worrying about any leaks (some of the rad valves are damaged so I can't turn them off). On a combi I think you have a drainage pipe but where should that be on a backboiler system?
I have a gas fire on my chimney breast with an access panel to the side of it but with the Gas and water supply going through the chimney but I can't see any drainage pipes - where would it normally be? behind the fire?.
