I am building a conservatory and a drain runs through the foundations from the property next to my property .Also I have a rainwater gully that runs into this drain which I want to remove.The drain is the old clay type,my querey is this can I cut the gulley off from the pipe leading down to the main drain and cap it using a drain plug and then seal it with mortar and then cover it with the conservatory floor.regards.
