Hi Guys,
In all this cold weather I have found out I have a huge draught coming from between the door and the frame, its between the middle and bottom hinge (hinge side). Looking outside i can see there is a gap of around 2-3 mm, door locks ok and is not catching anywhere, how can i adjust the hinges to "close the gap"?
The hinges have got a cover with allen key slot on the long part against the door (not techincal i know) a cover on the bottom with allen key hole and a cover on the top with what looks like a star plastic fitting.
any advice? many thanks
