Hi
I have just moved into my new home and have no chap to help with my home improvements. My front door is is upvc with glass from top to bottom, so it is very cold. I have recently bought a curtain pole to fit at the top of the door and there is a thin batten fitted over the door, I was wondering if anyone could suggest anything to help with fitting the rail. There isn't a lot of room at each side of the door, approx 5" either side. I am aware that it will be difficult to open the door with the curtain against it. I have found I could have bought a rail which fastens to the door and the curtain moves with the door, but I spent £20 for my rail and I have broken the packaging and thrown part away, so I will not be able to return it.
Do you think fitting further battens over my thin one would work or suggest anything else?
I am looking forward to any suggestions.
Thank you
Thank you
