Draughty PVC Patio Doors
8 Dec 2007
Antrim
Hi. Any ideas how to adjust Veka patio doors? I've three pairs in my house and they are all draughty on the hinge side. They open and close perfectly.
i assume they are the double outward opening type since you mention hinges?
the hinges should be adjustable via concentic adjusters above or below the hinge pins which will pull the door in or away from the frame using an allen key.
adjust one at a time keeping a very close eye on the door/frame relationship as you turn the allen key,this will enable you to see what turn does what adjustment.
the top adjuster on each hinge usually does the adjustment you need.the underside aduster usually does the height.
Thanks for replying. The doors all open inwards. There's allen key adjustment on each hinge at 3 points - top, bottom and centre where the hinge attaches to the door. Does this change anything?
hi top adjusts in and out on seal i beleive
bot adjusts height up and down
mid takes doors in and out towards centre
if doors do not look level across the top they may need toeing and heeling ( re packing as well )
you should also find on the slave door (the one that opens second) adjust ment for the centre
hope this helps
