Draughty uPVC Windows Fix
18 Oct 2011
Yorkshire
Hi all,
I have upvc windows in my home and several are draughty on the hinge side. When I've looked around the windows it appears to be a problem with the little plastic wedge things (sorry, I don't know the terminology) on the hinge side of the window. All of the windows have a similarly size wedge block thing on the frame. However, several of the windows with the hinge on the left have an 11mm block on the opening part and several have a 17mm wedge block thing. If I swap the blocks around, any window that gets the 17mm block if magically fixed.
On the windows with the hinge at the top, some have the 11mm block and don't have draughts. Two which are particularly draughty have the wedge on the frame but no wedge at all on the opening part of the window.
So my questions are:
1. Is it OK top buy some new 17mm wedge block doodahs and fit them to the windows that only have the smaller block? (Am I going to damage anything by doing so?)
2. Can I fit blocks to the windows that have them missing? If so, how would I go about it. Is there something in the middle of the opening part where the wedge should be that accepts a screw? Do I start out with a drilled pilot hole or a few taps with my bradawl?
3. What are these wedge things called and where can I buy some? I've found some things on eBay but they don't quite look the same (mine are squarer with a flatter wedged surface) and the distance between the screw holes is different - I'd rather use the same holes if possible. (The ones I found are at http://www.ebay.co.uk/itm/5-SETS-SA...t=LH_DefaultDomain_3&var=&hash=item721654a462)
Thanks for any help :)
