No the LP 811 is a single channel time switch for use with Combi boilers or for zone control, BG UP2 is a two channel programmer controling HW and CH, they are very different
Yes there are others too, what the numbers mean
LP522 means 5 day 2 day 2 channels, so you can set mon to Friday one set of times and sat and Sun at another set of times
LP 722 means you can have an different time for every day of the week
any LP ending in 2 is ok for yours, just depends how you want to control it
The LP range uses industry standard back plate and wiring so there are many that are a straight swap, no wiring changes required just two small screws , lift off , fit replacement and tighten the two small screw, simple as that
