Hi all,
I've read all the various threads here about the Digistat +2 and the Honeywell T40, but I'm still stuck.
I want to replace our old T40 with the Digistat +2. The T40 has red/live coming in to terminal 1, blue/neutral into terminal 2 and black (assuming switched live) into terminal 3. This mechanical thermostat works and switches the heating on and off, but it's not timer, obviously. Hence, the Digistat +2.
Followng other threads here, I sleeved off the old (apparently-now-redundant) blue/neutral and put the red/live to the common terminal in the Digistat +2 and the black/switched live into the second terminal down (it's not marked as 'terminal 2' but simply 'On'). There is a third terminal, marked 'Off'. Either way, this is a simple switching circuit so far as I can tell, so apart from the correct on/off action, it should switch regardles of whether my black/switched live is connected to On or Off.
But it doesn't. No matter whether I connect my black cable to the On or Off terminal in the Digistat +2, it won't fire the CH (on a combi boiler that, remember, fires just fine when the T40 switches).
I've now removed the Digistat +2 and refitted the T40 and all is fine. I've tested the Digistat +2's switching capability with a battery and a bulb, and it works as I'd expect. So, my question is, why won't the Digistat +2 switch work to call for heat from my boiler? The circuit clearly completes, because I can get it to power a bulb. So I'm foxed now.
If it helps, the boiler is some brand that I've struggled to find information on online -- an Intensa.
Any ideas greatly appreciated.
Harry.
Harry.
