Drayton hts2/hts3 cylinder thermo
29 Jul 2017
Changing old Drayton hts2 for the hts3. Can a charming plumber or sparky :)confirm that cable from old unit to new would be as follows, red is common, black is call terminal 2 and satisfied is yellow terminal 1? Cheers everyone!
No one can confirm that unfortunately, because there is no fixed colour scheme. The colours would have been selected on the personal preference of the original installer. Whilst it may be correct, to know for sure you should identify what each wire does first before you disconnect it from the original thermostat.
You should be able to find Common, Normally Open(satisfied) , Call (Normally Closed) on the new one as well. Or google it ..
