This is my first post here after being told it was possibly the best place to ask.
I am trying to sort out a central heating problem for some relatives I am staying with. So far the plumber has been a few times and the bill is climbing and I want to try to have a reasonable discussion with him about how the problem can be solved. I think I have found out what it is.
The boiler is a Worcester Bosch oil fired with internal pump and 3 port valve. Burner works fine and circulating water gets very hot but goes the wrong way.
The problem they had was possibly linked to the 3 port valve and a new one was procured from a Worcester Bosch spares agent. The device removed was an from Appliance Components and the replacement a Drayton/Invensys ZA3/679-3.
The data sheet says that when 240V is applied and the valve head energised Port A will open. However, looking at the unit on the side where the indicator is, there is a label with A on the left and B on the right, port A is on the right and B on the left (in the casting). When 240v is applied the indicator moves to position B - contrary to the data sheet but port A opens.
The plumber has installed the valve with B for hot water and A for heating - which according to the valve labelling should be correct.
However, when system goes "live" for hot water, the indicator moves to B, port A opens and heated water flows around the heating circuit and there is only cold water from the tap. Turing off the tap causes the flow switch to break and the boiler turns off.
Questions:
Is the valve labelled incorrectly?
Will turning it around solve the problem?
Questions:
