hi,
I have a new boiler system installed:
Boiler- Vailant thermoCOMPACT (sealed system)
programmer - Lifestyle LP522
room thermostat - Drayton RTS1
Drayton 3 Port mid position motorised valve
The problem i have now is my central heating system. The boiler starts fine and all radiator gets hot, but once the Hot water cylinder gets hot enough, the boiler will shut off.. The radiator get back to cold and the boiler wont startup....
I have checked the wiring and it is all correct according to the boiler manual.
However I am thinking the problem might comes from the room thermostat, because when i rotate it, there is no "click" noise.
Does that mean it is faulty?
many thanks in advance!
