Hi everyone
My heating system consists of a motorised valve for the heating and a Drayton Tapstat valve for the hot water. The system is in the region of 25-30 years old.
Recently a bit of a throbbing noise has developed when the hot water only is running. If the room stat is turned up, thus opening the motorised valve and allowing water to the radiatores the noise stops. I have a feeling that the cylinder valve is possibly not fully open. It is turned up to MAX and the sensor on the end of the caplilleray is laying on the floor and not in contact with the cylinder. I have fitted a cylinder stat wired to the programmer to start the pump & boiler when required.
a) does a sticky valve seem the likely cause?
b) how can I test it?
c) would I be better off replacing it with a motorised valve?
Your opinions and advice would be very much appreciated.
Happy New Year to all
Stoff.
Stoff.
