Drayton Tempus 7 with RTS 5
5 Mar 2009
Kent
Not happy with the manual RTS 5 thermostat that works with the Drayton Tempus 7. I want to get a digital thermostat but does it have to be a Drayton one? Preferably want one that you can actually carry round the house with you as i feel its been mounted in an incorrect part of my house.
Or would it be best to replace the Tempus 7 system completely?
Need a bit of advice.
edit - If it helps i've got a conventional boiler with a hot water tank in the loft and a central heating/water pump.
No
Then you need a wireless stat which may not give good reception an all rooms.
You have to be careful if you have a TRV in the same room as the stat and the TRV is set to a lower temperature. The stat will never turn the boiler off.
If you have a combi boiler it might be worthwhile installing a Programmable thermostat. If you have a HW cylinder you could retain the Tempus 7 for the HW and install a programmable stat for the CH.
Thanks for your reply, gives me something to think about.
