Drayton wireless receiver ..removed from boiler
30 Dec 2013
Hi ..I've removed the Drayton receiver from my baxi combI boiler
Completely removed the wiring but the CH is not responding to the original timer although it's working ..help !!!!
the wireless receiver will have had probably 4 wires to it a L a N and the other two are the switch wires you need to link these two wires
No I've completely removed the Drayton from the boiler ..all wires ..this is the original timer on the boiler that's working but not allowing me to turn on the CH ....
what wiring did you use to connect the replacement clock up and what terminals have you wired it to , a pic would help
The original timer on the boiler ...it shows time and programmes ..didn't need rewiring as it was still connected ...it's the Drayton wiring I've removed ...
Then you will have to link out the switch wires for the thermostat as already advised, which Baxi boiler do you have ?
It's a baxi combI 80 ..the wiring for the timer is wired in to the switched on the board ..the Drayton was wired into the switches on the far left looking at it ...do you mean transferring the wiring for those you be stated to the switches where the Drayton wiring came out ?
the replacement time clock must switch between terminals 1+2 on the boiler
Think I've confused you ...it's not a replacement it's the original timer from the start ..a Drayton was added later ..this I've taken out ...
So what you are saying is that where the original timer is now wired in ..needs to be rewired back to where the Drayton wires came out ?
Sorry for the confusion
The drayton would have interuppted the clock wiring, your clock will have a live and a neutral for the motor or display supply and another two wires, these two wires must connect between terminals 1+2 on the boilers connection strip, if you just put a link between terminals 1+2 then your heating will work but the clock wont till you can get someone who knows what they are doing to have a look at it for you
