- Joined
- 2 Dec 2017
- Messages
- 6
- Reaction score
- 0
- Country
Hello all, I hope someone can help on here with this problem, I'll try and explain as best I can.
I have a glowworm boiler (non combi) with a water heater tank in one of bedrooms, it's controlled by a drayton lifestyle LP111, it works faultlessly with the only issue is I don't have a thermostat so water temperature has always been controlled by the setting on the boiler it's self, now this is the part that's a bit different to other systems I've seen, when the boiler is on if I want heating I turn a manual valve in the same cupboard as the tank, the valve just has heat on / heat off.
Anyway I've recently managed to aquire a drayton wiser kit 2 which is a 2 channel system for non combi boilers like mine, I've swapped over the controller no problem paired the thermostat and everything is OK apart from one thing.
Via the app or on the controller panel itself I can not get the boiler to fire up if I used the thermostat or "heating" on the controller panel, the light will come on the same in the wiser app if I increase the thermostat temperature is actives the receiver and the light comes on again to say is working but the boiler stays off, if I use the hot water button/app request the boiler fires up fine, this makes me think my old controller was only wire for 1 channel (hot water)
I hope that made some kind of sense.
My question is can I bridge across so when the controller receives the heating/thermostat information as it currently does it actually switches the boiler on, or do I have to move the current single channel wires from hot water over to central heating.
Again I hope that makes sense and I really appreciate anyone's help.
