I have had repeated problems with one of my 2 ZA6 actuators, with its microswitch not switching when the actuator is commanded to close the valve. The result is that the pump and burner continue after the flow has stopped. The condensing boiler doesn't like that, obviously. I have sourced and fitted several new microswitches (SAIA-Burdgess XCG3Z1) - each time the new switch behaves for 6 months and then becomes intermittent. I'm about to do the same again but wonder if I'm the only one this has happened to, and has anyone any advice?
Martin
Martin
