She keeps on about when I'm going to fix our dribbling kitchen tap so off I go to the local hardware shop and get a selection of tap washers... it's 5 minute job right?
None of the washers fit! Maybe I should say at this point,the tap is a swan neck pedestal type,so back out to the not so local plumbers merchants where I get sold a whole new internal gubbins...£13!"no point changing the little silicone seal,it's the discs inside that wear out"
All fitted...tap still dribbles when you turn it off,doesn't drip once it's off but doesn't shut off nice and cleanly as the hot side does,so being a bit of a bright spark I swap the hot gubbins with the cold but it makes no difference('cept the tap works the wrong way round) so I put it all back as it was,used the new internals as I doubt the merchants would take it back once fitted...she comes in..."I thought you were going to fix that tap" what's going on?any ideas chaps?
