Drill bit sharpeners
30 Dec 2018
Up North
At that price point you have to manage expectations of what it will do.
I've always found that type of equipment poor.
Looking on YouTube there isn't much to look at which tells you something.
Maybe watch this as a similar machine.
May help you
It seems I was guessing the setup part correctly, but I was finding it left the heel of tip of the drill bit higher than the leading edge. If I ground the heel away manually, it does seem to work quite well.
This sort of setup works pretty well
There may be a need to mount the grinder spaced up some how. Depends on size. Both need fixing in place. Personally I wouldn't take of as much as he has per go. Best use the fine adjuster. With a green grit wheel carbide can be done as well.
There are machines that can do cross point but the costs increase.
