drill wont come out
19 Mar 2007
hi - ive got a black and decker cordless percussion drill..very powerful, goes through anything...sounds like a jet engine when working...anyway...it has a keyless chuck, where you tighten or loosen the drill bit by pressing a little plastic tab on the chuck and then either release or tighten the drill bit....problem is when i press the little tab on the chuck the drill cant be released or tighten the chuck turns and there is no resistance so i can loosen the drill bit...seems like the plastic bit on the chuck has broken or is not working..any ideas on how i can get the drill out or open up the drill..
If the drill has got a reverse switch put it in reverse, hold the part of the chuck you would usually turn to release the bit, and squeeze the trigger.
And marvel as the little toy fails to undo the chuck.
Failing that, there should be a couple of flat sections on the base of the chuck. Grab them with some pliers.
