Hello,
Sorry this may be a very dumb question
Trying to attach a retractable garden hose to the external wall, instruction said drill a hole with 10mm bit which I did but the plastic anchor goes in the hole too easily so the bolts are not screwing in.
Now, would it be wise to ignore the holes in the brick and drill a new ones close by or should I buy a bigger size anchor and bolts to fit the drilled holes? Not really sure if there is anything wrong with leaving 4 holes open in the brick.
Thanks,
Thanks,
