I need to excavate at the side of my house to a depth of about 2 metres. I want to do this to about 1 meter away from the walls of the existing building and will need to provide a retaining wall so as to prevent slippage of the end wall of the house (stone).
My only option, as I see it, is to drill bore holes (piles) with an auger and fill them with compacted, reinforced, structural concrete.
The soil is rocky and VERY stable. We have tested this by digging down over 1.5 meters till we hit water and then leaving this to collapse over time. It has still not collapsed after about 5 years!!!!!
My question are:
1) If I am excavating to a depth of 2 metres, how much deeper do I have to go down bearing in mind that there will not be a traditional footing. If I go down 3 meters in total (or into rock at least) will this be sufficient?
2) If I hit rock, how far into the rock should I cut to stabilise the foot of the pile?
3) What diameter bore holes, and thus piles, should I create?
4) Should I complete the job by tying the tops with a cast concrete beam to tie all of the piles together?
If anyone can help of point me in the right direction, I would appreciate it.
Matthew
My question are:
Matthew
