drilled through tile
19 Mar 2007
hi guys..in my haste to finish the bathroom, i drilled through the tiles in the wrong place to put a mirror up, how can i fill up this hole....the tiles are beige in colour ?..cheers
why don't you replace the tile?
it can be done, scar free too. provided the tiles were fixed fairly recently, of course.
i suppose i could do that, got a few spare..i thought there might be some other solution like some typr of filler ?...
Holes are usually filled in with grout, but if you've got spare tiles you'd be better replacing it as noseall says.
What's the wall made from? I'm just thinking that if it's plasterboard, you might struggle to get the tile off without causing serious damage to the plasterboard. On the other hand, if the adhesive is still fairly fresh it might come off relatively easily.
