I need to drill a 16mm hole in brickwork. Now today I was drilling 8mm holes in the very same brickwork using my corded 400W Bosch hammer drill and made little or no impact so ended up having to drill into the mortar instead to attach a bracket.
My next little job involves having to drilling into this brickwork. My question is can I get diamond tipped bits that will allow me to drill 16mm holes with my existing drill (max shank size it will take is 10mm) or am I going to have to hire a larger drill. If I do have to hire what kind of bit should I use so I can get through this brick?
