Drilling 750mm down for 4 inch duct - how?
8 Sep 2012
West Midlands
i am putting a new water pipe into our garage.
i have dag the trench outside and now i need to create a hole in the garage floor and then remove the brickwork below to insert a underground pipe bend (duct for water pipe).
Whats best way to do this? should i use breaker on the garage floor, then remove some of the brick to insert the pipe. then i should cement the garage floor up.
any tips? tools to do it?
is it likley i will need any Damp proof membrane as im going down deep into the garage?
As far I have have found water pipes are not put in ducts. I suppose it depends what sort of pipe you are using. I would just wrap some cardboard and plastic bags around the pipe where it passes through concrete.
I would not ever use a breaker in these circumstances, the floor might break up in some unexpected way. The vibration will not do it any good anyway.
The main problem is that the pipe in the trench is horizontal and I expect you want the pipe to rise verticaly within the garage next to the wall. So either you need to put in an underground right angled connector, which you can tighten in-situ or bend your pipe into a suitabley small radius.
I think the way I would do it would be to use plastic sleeved 15mm soft copper (its used for oil tank feeds to oil boilers). Drill a 25mm hole as tight to the wall as possible, aiming to exit at about 18" below floor level. Find this hole in your trench and open the top of the hole up , so when the pipe has a reasonable radius bent on it it will do the right angle change of direction at this point.
To make good the floor , just poke some foam into the hole and put some mortar on top.
Frank
There are building regulations for types of pipe in concrete. Don`t remember cardboard or plastic bags being advised though.
