drilling a hole in wall
21 Feb 2010
Surrey
Yesterday I was drilling a couple of 5mm diameter drill holes for a curtain rail
I had an hammer drill (electric)
I first tried with the hammer action off, and it made a perfect 5mm hole, but not quite long enough for the raul plug
I noticed that underneath the paster is a very hard substance, something like steel
I cant get through it, with or without hammer action on, with concrete or HSS drill bit, makes no difference
When I turned on Hammer action, it made the 5mm hole turn into a 7 or 8 mm diameter hole, because it makes the drill go all aggressive, if you know what i mean
After 2 failed holes, I gave up frustrated.
What can i do ?
Put your rail a few inches higher up.
thanks andy
until today i didnt know what a lintel is
now i know how to deal with the problem
im going to use a wood baton..........
Use a masonry bit until you hit the lintel then change for a steel drill bit to go through the lintel.
But you'll still need to drill into the wall to fix the batten.....
3 weeks have passed and I still havent got around to attaching the baton into the wall
can any tell me how can i attach the baton to the wall...........
I can only drill into the wall to the depth of the plaster.........which is about 2cm
How can I screw in the baton.........i'm a total diy novice
Obviously i cant use a rawl plug
Get a better drill and better bits and you'll be able to drill the lintel. If it's concrete, go borrow an SDS+, if it's steel, buy some real HSS bits, not the generic five penny a piece ones from the discount store down the road.
