I need to drill two 30mm holes to plumb in some solar panels. The roof has dreadnought plain clay tiles and I have a pair of lead flashings with a collar to allow 22mm copper pipes.
Two questions: What is the best drill bit for this, bearing in mind it's not going to see much use and I don't have SDS? Screwfix has some diamond tipped bits ranging from 15-65 quid, not sure whether I need water to get through roof tiles. Also where best to drill? As far as I can tell, the overlap is mostly three tiles thick, except at the bottom of each tile, there appears to be a strip where only two tiles cover would also exit between the battens. Is this correct?
