I have a 10mm glass fishtank and i want to drill a 55mm hole in the base.
Im after some advice on drilling glass,and here is how i was thinking of doing it.
use a diamond bit,,use a battery drill,shall i use on torque setting?
fill the tank to say with 8mm of water,cut a hole with the bit 1st through thin ply and use as template.
Now is the key not to use presure and just let the weight of the drill do the cutting?
shall i got very slow or will that chip at it?
Ive not drilled glass before only cut it,
thanks for the help
craig
thanks for the help
craig
