Drilling holes in brick to make my own airbrick
6 Jan 2025
I live in an 1860s cottage, we have a porch extension built around 30 years ago, which has a ventilation issue resulting is a buildup of mould and general damp feeling throughout the winter. I'm about to renovate the porch and part of this will be looking at installing some kind of ventilation.
Its a single skin brick structure and seems like an air brick could be a good option. My question is, is there any issues with me drilling a series of holes in an existing brick to essentially make it an air brick? This seems like a simpler solution that taking a brick out and replacing perhaps.
Replacing the brick is a lot quicker.
Also, a brick can only take a few holes before it starts breaking up.
Ok, thanks Johnny. I will replace a brick in that case. Generally where should an air brick be installed? I'm thinking at around head height as planning to install a low wattage bar heater one corner to help with moisture build up, with the thought process that the air will rise and escape through the vent
Why do you think the space is damp? Is warm air from the house leaking into the porch and causing condensation? Is there a leak letting in rain? Do you fill it with wet coats and boots?
Ventilation may be useful. Heating maybe not.
For ventilation you need a means for cold air to enter low down and hotter air to exit higher up. But if it is a regularly used porch to enter/exit the house then I would have thought it would get plenty of air changes.
I'd give it a go: if the brick doesn't break you have your air brick,if it does it's part broken out. Don't go mad with an sds.
I wouldn't. Vandalising a weathering face of a brick is bonkers. Plus there is zero insect screen and a good chance the holes will block up.
