im trying to put up some curtain brackets but the window lintel has steel inside - ive have tried using hss drill bits but have failed - they get blunt and super hot can anyone advise on how i can drill into the steel lintel - thanks
OK, so I'll buy a set of cobalts rather than just one 8mm. I was watching this video on drilling steel plate by hand drill, seems there are precautions to take because the drill bit can 'stick' towards the end, creating a sort of whiplash effect on the drill.If I was doing the job I would centre pop and pilot , you don't need that much power to drill small holes in steel so your 600w is more than enough.
litl
