AirGuitar said:ok thanks for your help. Before I posted my first message I'd had a go at drilling it. I got about 2-3mm and then no matter how long I drilled there was little effect. This seems to be what you described about hardeneing. If it is irriversible I'll have to drill in a new place, and I'll try the cooling method along with working up in drilbit size. The size of hole I'm retying to make is about 8mm diameter.
TexMex said:some shield anchor bolts should do the trick.
