I have some window handles in the bathroom which are quite loose (the handles but not the mountings). They've been like that since we moved in (ten years), but I've now decided I want to replace them. The problem is that, apart from one, all the fixing bolts have pozidrive screw heads which have (before we moved in, I should add!) been worn virtually smooth by camming out and I cannot remove them.
For that reason, I think I shall have to drill pilot holes and get some screw extractors to get them out. As I have never used these before, the question I need answering is how to drill the pilot holes - quick drill rotation or slow? I've heard both options. Also, is it necessary to use a lubricant (I have WD40)?
Another option is to 'drill the bolts out'. I take it that this is to remove the head, and allow removal of the handle, but wouldn't that leave the rest of the bolt where it is? If so, I'd still have the same problem when it comes to fitting new handles with new bolts.
