drilling tap holes
11 Aug 2005
Hello i'm buying a bath with no tap holes! what size and what kind of drill bit should i use to obtain tap holes? (5mm thick acrylic bath with reinforced fibreglass)
thanks bugser
I can't help wondering why you're buying a defective bath. If you complained to the manufacturer, wouldn't they send you a packet of holes?
Spade bit or saw bit. Get assistant to hold a block of wood beneath to keep either centred as it cuts through the bath.
Measure twice cut once.
