I'm installing a new water main, the pipe must run through a 100mm duct.
The pipe will enter the property through the Cellar wall.
I'm hoping to do this using a core drill.
I've drilled a pilot pilot using a 10x1000mm sds bit, with about 200mm left over.
Am I drilling through the foundations, can I drill through here. The old pipe entered slightly higher. (Too high - not to water regs).
Will the strength of the building significantly weaken through me doing this.
The property is a three story (+ basement) terraced house built around 100 years ago.
